I do a lot of 2nd gear pulls and I have almost no spin, so tires are not an issue in my case.
You lack power then.
ok grandmaI do a lot of 2nd gear pulls and I have almost no spin, so tires are not an issue in my case.
Also note that the two things the GT stock clutch does not like are 1) riding the clutch out from a dig and 2) powershifting. In my Z06, I had a huge amount of drag strip passes using my left foot to do all the work leaving the line. You can't do that with a GT. You'll be left smelling metallic stank for 45 minutes inside the car at best, and at worst, you'll kill it. As for the powershifting, the car is MUCH quicker when powershifted, but you will kill the clutch. I'm sure that's what did mine in. It's fun to keep that boost cookin while you can, but it's definitely a costly extra couple tenths.
My car hasn't been driven lightly and I haven't gone thru this clutch yet.
Here's the screenshot. The different options it appears are based on different torque spec................ EP - they even have a drift clutch for you!
EP doesn't need much of a clutch to move it to and from the transporter. :lol
I believe Stillen also makes a full race clutch that they use in their race car. It might be an alternative to the Spec.
That is because you forgot to press the button in 2nd. :lol
Soroush my friend
In second gear I can easily get into trouble aka spin wheel spin and the same is true in third when the stars are aligned just perfectly.
You must have the "easy on hardware 825 horsepower package"
All the best
ok grandma
