Brian-
Sorry to hear about your uncommanded WOT event, but it seems like you reacted and handled it in your typical professional way. Glad you had the uneventful pull-to-the-curb outcome.
I have read the posts and considered others opinions. For what it is worth I agree with Ice and think it unlikely any cylinder back pressure could effectively work its way upstream thru the fairly deep intercooler heat exchanger, thru the screws of the Lysholm supercharger, travel back another 2 feet thru the throttle body and into the "large volume" inlet box and still retain sufficient pressure to apply a pressure differential across relatively new air filters to cause the pictured filter deformation. It is perplexing.
To me it appears the root cause of the incident is failure of the air filter perimeter gasket. Perhaps, as has been suggested, a molding problem with the perimeter seal material compounded by as Jeff identifies, engine bay heat. Disconcerting is this was a MotorCraft OE filter as I am a strong supporter of using original Ford fluids and filters (I concede oil) as they were designed and tested for our specific application.
Brian,
An excellent post and thanks for the pic's. I'm assuming that your filters were the recommended FORD. Have you considered using K&N's. I've had no problems with K&N what so ever, (I change them out regularly) have noticed a slight gain in power by using them vs FORD's and I've 9K+ miles on #1049.
Any Forum Members welcome to chime in with opinions FORD vs K&N.
Best,
Paul
Paul, not to criticize, but I am always skeptical as to anecdotal testimonials about "slight power gains" reported by users. It is impossible for anyone driving a 550hp powered car to "feel" plus or minus 6 hp or so which the manufacturing hype would lead one to believe. Decisions should be made on data collected.
I would continue to use the OE Motorcraft filters and monitor/inspect them carefully prior to initial install and frequently thereafter. Perhaps a GT team member might want to closely examine one of the failed filters to ascertain if the seal material conformed to intended properties.
