Standing Mile
SAGT
83
Has anyone run a NFGT in a standing mile event yet? My wife is registered in our 2020 for this March. just curious on speeds. I'm guessing 185 - 190 depending on weather.
SAGT
83
Thank you. That gives us a good idea on what to expect
Also FlagstaffGT has taken his NGT to the Mojave Mile. There is a report somewhere here on the Forum.
texas mongrel
1,686
Don’t know why the NGT isn’t faster. You’d think with its low-drag and 647hp it would run well into 190. My 06 when it was bone stock ran 180 at the Texas Mile. I’ve noticed the same with the NGT at COTA - no faster down the back straight than my old 12C
Drag v. downforce
Reactions: JWZ and sahlman
sahlman
Ford GT Team Alumni
Jul 21, 2011
339
Verona, WI
Drag v. downforce
Sinovac is right...the NFGT has a lot more downforce stock than the '05 - '06 and that also means it has a lot more drag unless it is a lot more efficient (lift / drag ratio). Which I don't think is possible.
Reactions: Ed Sims and JWZ
BIGFOOT
751
Northeast
Has anyone run the standing mile in a bone stock new GT500?
The '05-06 GT is close to aero neutral while the NGT has much more downforce (even in Velocity mode). The '05-06 became an amazing top speed car because of the lack of aero & engine with lots of modification potential. That combo has made for a 300 mph+ street car. No other car can do that in a mile.
sahlman
Ford GT Team Alumni
Jul 21, 2011
339
Verona, WI
Ed, while a lot less than the NFGT, the '05 - '06 FGT has 500 lb of downforce at 180 mph (between 60-70% of that on the rear tires). That goes up with speed squared (so 617 pounds at 200 mph). If you get to watch the '05 in the 180 mph region plus it shoves the car down almost to the bump stops if everything is stock. It was pretty cool to watch the car suck down and drive it that speed at Ford's Michigan Proving Grounds (MPG) 5 mile oval...5 laps of full throttle until empty. You could see the pressure wave off the front of the car. So damn cool.
So not huge, but definitely not "neutral". But yes surely a lot less than the NFGT.
got any pictures?
sahlman
Ford GT Team Alumni
Jul 21, 2011
339
Verona, WI
Sorry Buddy, I wish I did have pictures of these runs. McGowan may from my runs or Walsh's. But I don't think so.
The downforce is very obvious when watching the GT's in the mile venues. They are VERY hunkered down and there's no perceptible height change as the driver transitions off the throttle at the end marker. Solid, confident, impressive.
Reactions: sahlman
