GT after 12 hours racing
nz05gt
380
taupo new zealand
Just thought you might like to see what the GT looks like after 12 hours racing
Just a few more.
So far no noticable wear in any joints
Wil do an cylinder leakdown tommorrow
:thumbsup
Great pics!! Thanks for sharing an experience my GT will never have! :lol :cheers
She looks ready to go play again
Thank you for sharing
Wow, simply fantastic!!!
Just did a cylinder leakage test and found all cylinders between 5 & 8% leakage and used 1.5 litres oil
:thumbsup
Neil
Enjoyed the post. I am jealous...
If you need a co driver ................?
Will travel to race !!
Neil looks like you changed the top shock mount design?
Are the upright also modified? The upper ball joint is also flipped.
Beautiful Neil !
Yes I have shortened the shocks buy 1 inch as we had to much travel for racing
The ball joint is now a spherical joint mounted in a new chromemoly top A-arm as we had 2 inches wheel deflection from the top arms under acceleration to braking and this movement would coil bind the springs 600lbs under acceleration this was with the billit a arms now I have no deflection.
Trust me when I say it was frightening when you changed gear at 150 mph in a corner and it would jump across the track 10 feet:eek
I have also removed the rear cross brace and made an new chromemoly tube one that picks up all top a-arm bolts from the inner side so it triangulates between both side like a roll cage for the top A-arms.
:cheers
Neil
MR2
this is a pic of the GT before we changed the top arms on the rear
Note how much Toe in is on the rear the GT is set up with toe out in the rear.
IT is under hard acceleration at 100mph in this photo, it was like driving an old formula 5000 lola
Please note this GT has NO rubber bushes in the suspesion it is all rod ends and spherical balls so it exaggerates everything.
:cheers
Neil
Beautiful Neil !
Thanks Torrie
now you know why I wanted the best tune in the GT
:cheers
Neil
ps Thanks for working with Paul Isaac with the GT tune
Thanks Torrie
:cheers
Neil
I can tell you firsthand Paul is a fantastic guy to work with. I have no problems helping out when and if he needs anything that is for sure. Thanks for lining me up with him.
