Steve,
I wouldn't worry about the FGT being any different than any other car, especially any other high horse power car. The physics are exactly the same. If you exceed the coefficient of friction, your tires will loose grip and you will spin the tires. It's that simple. Tires may seem to have less grip in a turn when you apply power but this is not true. The amount of friction the tires can withstand is the same. What has changed is part of the tire's friction is being used by the tires to maintain grip in the turn and is not available for accelleration (either for slowing or speeding up). If you drive too fast into a corner, you are going to go off the road. If you are too heavy footed especially when in a turn, you will go off the road or at the least spin out. All vehicles, vans, trucks, cars, etc. have their limits. If you exceed their limits, you will pay dearly for your mistake. That is all that is happening. As twobjshelbys said of the short wheelbased Cobra, it will snap into a spin in a heart beat, but under the exact same conditions, the FGT will not spin due to the FGT's wider stance, lower center of gravity, suspension improvements, wider tires, etc. If you want to hammer the gas pedal on a Cobra, you had better be pointing it in a straight line or you will be swapping ends in a fraction of a second. You never hammer a Cobra while in a turn, curve, or rock the steering wheel back and forth to break the tires loose like you see people do on the old '60s muscle cars. That is just flirting with disaster. Learn how to control your right foot and you will be OK.
