The manual says you should not break in the engine. Just don't drive at the same speed for prolonged periods for the first 1000 miles.
What is your opinion guys?
Why question the manual?
My own darn self, I conservatively, casually, ran the revs from off idle to 3,500...maybe 4,000...up and down constantly...varying the speed & gears all the while. But, I never even ATTEMPTED to FLOOR it.
The factory DOES install (as a part of the engine control software) a throttle limit program that overrides your FOOT for the 1st 50 miles or so & won't ALLOW rat crazy power rips during that time even if you wanted to. (That alone should tell you something. :wink)
So is this achieved via the superchargers bypass valve? Since it is not a drive by wire car, it can't limit WOT. Or is there a temporary rev limiter?
EP is right about the reduced power until 50 miles. It is too bad EP never really felt the full output of the engine.
about the engine temp in the dash. Is that water or oil temperature?
In my other cars I have both and water goes faster than oil. Some guys told me that with a dry sump engine water and oil temp are pretty much the same because there is much less oil in the engine itself.
