starter won't turn at all - sizzling sound
spddmnjay
422
Alberta, Canada
I know that this has been discussed in other threads but my situation is a little different.
While installing Stainless Works headers I totally forgot to disconnect the battery. :confused Too excited to get them installed. So during the install the header touched the starter and SHAZAM!! Sparks flew. :eek :ack
Completed header install, installed short shifter and changed oil. Went to start car and nothing. Gauges power up. Fuel filter powers up. But no starter action at all. As I hold the starter button I hear a sizzling sound around the starter. :willy
Did I cook the starter?
Sadly; maybe
I would unplug the white connector on the starter and with your gal in neutral and the e-brake "fully" engaged use a jumper lead between the large post on the starter and the small spade connector within the area that the white plug was removed from; when the jumper lead is touched at both points the starter should spin the motor; if not then at the very least the solenoid is history.
Hang in there
Sadly; maybe
Hang in there
Sounds good my friend :thumbsup
Cheers
Jason
I would unplug the white connector on the starter....
Good advice from Shadowman to test Starter/Solenoid. The fact that you can hear some "sizzling" would indicate (unfortunately) that a fuse didn't go :bored
This white plastic connector also needs to be shielded from the heat of the headers. Keep an eye on it after you get the starter fixed as you may consider to add some kind of heat shield to protect it. I've seen a couple of completely melted connectors due to aftermarket exhausts - though I am not directly familiar with the set-up that you have.
Very good advice to shield the white plastic connector. :thumbsup
So is it possible that a fuse went?
p.s. I love the products I purchased from you :cheers
It's fixed! :banana
Turned out to be the starter relay fuse.
It's fixed! :banana
'jay, where is that fuse found?
It's fixed! :banana
Thank you for the shared results; it would appear that you dodged a bullet as such I am very happy for you.
I appreciate you taking the time to bring shared closure to this issue as all too often there is not a shared resolve and thread simply lingers on.
FYI; typically I wrap the solenoid with a piece of Mylar to reflect the heat away from the associated wiring at the starter; I know this was not the issue in this case and yet as mentioned by another it is a good idea.
Fuse is located in the fuse block that is below the front luggage compartment under the hood.
I can't take credit for finding the problem. A Ford Tech came to my house and found the problem. He swapped out the fog light fuse with the starter relay fuse (apparently same fuse). And sure enough the car fired right up.
Dodged a big bullet. :thumbsup
I will definitely wrap the starter to protect it from heat. Thanks guys for this tip. :cheers
