Seat bolts...A Warning, PLEASE READ
thegtguy
*Supporting Vendor* GT Owner
Apr 20, 2006
552
MI
As many of you know we have worked on quite a few of the X'1 and we have found another issue that should be known to the X1 owners. We have seen this a few times now and don't think it is a one off issue anymore. The issue is with the washers that they put under the seats because of the reinforced floorpan. They used the original seat bolts (which are not long enough any more) causing only about 5 threads of bolt engagement. On a car that the seat belts are bolted to the chassis probably not a big deal but since the seat belts are bolted to the seats and the seats bolted to the chassis this is a big deal. On the cars that we get through the shop we will check as replace these as needed with the proper bolts.
Just added a pic of the OE bolt, longer bolt and the washer that is used to space the seat track assembly away from the reinforced floorpan.
Shelby#18
GTX1 Owner/Moderator
1,623
Nev./So. Cal./Minn.
Thank you Rich for this post. What bolt would you recommend other owners do who do not have access to your shop, or services because of distance. Could they purchase the bolts from you and have it changed at their convenience?
thegtguy
Apr 20, 2006
552
MI
Bolts
I will have the exact bolt spec that we use tomorrow when I get back to the shop. Then the owners can either get the bolts themselves or they can let us know and we can ship them out. So either way.
Shelby#18
1,623
Nev./So. Cal./Minn.
Thanks Rich, I'd hate for the seat to come off in an accident. That'd make for a bad day. :frown
Oh, have you changed mine, on both cars?
centerpunch
ex-GT owner x2
953
OH/NC
Speaking of loose seats, here's a very lucky guy:
http://www.youtube.com/watch?v=QkDm-BNpasQ
Great cautionary post!
cedarstang
As a new GTX1 owner THANKS!
thegtguy
Apr 20, 2006
552
MI
On the blue car yes. You will have to check on the Tungsten.
The bolts that we use are Socket head cap screws that still have the clearance needed for the seat tracks.
It is a 10mm bolt, 1.50 thread pitch, 30mm long (thread length only) and grade 12.9. It uses an 8mm allen wrench.
Great post; thank you
anya
NGT,GT/GTX1 Owner
178
Seattle
:thumbsupRich Thanks for the post Just had the car serviced and they found a loose bolt. Now I am off to the screw store.:thumbsup
Jim
Shelby#18
1,623
Nev./So. Cal./Minn.
Rich, I guess I'm on my way to the store also. The Tungsten also has the short bolts. :frown
HJP
GTX1 Owner
225
Chicago
Rich,
Have you done the replacement on ours already?
Thanks for the post.
Rich; thank you for the "great" information
I just replaced them on a GTX-1 and I was dumbfounded when the OEM bolts were removed as there were barely any threads engaged.
It could have been a serious issue
All the best
Kirby Vieira
GT Owner/B.o.D
Atlanta
Thanks, Rich. I'm late to the game but will check it out. :cheers
thegtguy
Apr 20, 2006
552
MI
Bolts
Rich,
Took care of it last week. That was another car with short bolts.
Pic of OE bolt with aftermarket washer stackup and the new bolt (bolts) we put in.
Steve Woodrough
GTX1 Owner
57
St. Petersburg, Florida
Thanks, Rich. We replaced all eight bolts this past weekend. Actually, Bernard Guerin did the work while I watched.
Keep up the good work.
Steve
