oh dear gt suddenly become incontinent
panterasteve
13
england
whilst taking the gt for a drive suddenly became aware of a horrible din coming from the engine which was related to engine revs.
wasnt far from home so limped the gt back to home with no drama.
on inspection i coulds see red fluid all over the floor pans and immeadatley checked power steering reservoir which was now very low.
so i topped the fluid and let the pump bleed it self and releived to say noise has totally gone:thumbsup
i now removed the pans and could clearly see the bottom ps hose pipe was leaking where the pipe union screws into ps pump ,checked the union which wasnt very tight but even now ive tighten it as far as i dare go it still leaks although not as bad.
what beats me is suddenly after all these years does the pipe union start to leak
and as anyone had same problem at all ?
Happened to me at the VIR rally. Not a drop for 10K miles then all of a sudden it was so loose as if it had never been tightened. GT guys saved the day.
yes mines just coming upto 10k too!
did you have to replace pipe?
Nope. Tightened the fitting, added fluid and bled, no problems since. It just worked loose. That was about 7K miles ago.
I've noticed some fluid around the front steering column... corrosive stuff.
The only thing I can think of that is corrosive is brake or clutch fluid.
ive removed the hose and its not a compression fitting so i dont recommend re tightening unless its loose!
there actually a rubber o ring there with one at each end of the hose.
now mine looks to be ok no splits etc so i may try a slightly bigger size o ring before replacing hose .
incidently the pipe numbers are 4G7V-3A719AF 21GT-10003D,the o rings look different sizes one red and one black.
does anyone knows how much they are please?
The Red one is most likely Silicone Rubber, the Black one probably just standard Nitrile (Buna N). Which o-ring was at the leaking end of the hose.
I strongly suspect that the o-rings only come as part of the assembly from Ford so you will have to find your replacement from another source however, it shouldn't be too difficult.
Mike
the black was leaking and on closer inspection the red one is slightly bigger which was bone dry!
Unless someone else chimes in with more specific info, what you may have to do is to measure the OD of the tube that the o-rings fit on and then the ID of the port into which they fit.
Then if you go to this O-ring Handbook, I am sure you will find the sizing info that you need.
Look in the Metric section for the size number, then select a material from the various listings.
I would go with either the "standard" which is Nitrile (Buna N) or Viton which will stand up to almost any hydrocarbon based fluid. Power Steering Fluid used to be regular Automatic Transmission Fluid but today, they have engineered a special (read more expensive) fluid.
Mike
Here are a few photo's of my hose that failed a few years back. Denis located the failed "pin holes", and I know of others that have had the identical failure.
http://1fordgt.com/20002009/BACKUP/2009/EVENTS/CARLISLE/PSHose04.jpg
http://1fordgt.com/20002009/BACKUP/2009/EVENTS/CARLISLE/PSHose03.jpg
http://1fordgt.com/20002009/BACKUP/2009/EVENTS/CARLISLE/PSHose02.jpg
http://1fordgt.com/20002009/BACKUP/2009/EVENTS/CARLISLE/PSHose01.jpg
Good luck.
Pete S.
If that is the case with yours and a replacement one from For is either unobtainable or stupid expensive, try a Hydraulic Equipment repair shop. There is always a possibility that it is a "standard fitting" of some sort, though knowing Ford and some of the other fluid line fittings I have run into that are ever so slightly different from their similar "Standard" fittings, i wouldn't hold much hope.
Mike
I agree with Madferraristi.
Any competent hydraulic shop should be able to build you an exact duplicate in short order. That kind of stuff is their bread and butter. I am sure they can source the weird fittings too if they are not standard.
hi pete thanks for those photos made me have a second look a bit more closly at the pipe !
and looks like ive got a very faint crack right where yours has gone too.
how much did your pipe cost as if its not expensive will keep gt original?
Nice information. 2 failures so far on this forum. I would say something to watch for for all owners.
Not expensive at all. I carry a spare in the trailer as well. This is an easy fix, with Ford spare parts.
Good Luck,
Pete S.
just ordered with torrie who responded instantly to my message ,hows that for great service !
i need some luck as in 1 week ive managed to run over 1 sheep and a 1 rabbit ! R.i.p
Thanks Steve, I have got you handled now !!
