Engine heat affecting clamshell??
bob700
Jul 13, 2007
10
Has anyone noticed how the underside of the clamshell that sits directly over the muffler can develop small cracks from the heat generated by the muffler. I have always been concerned about this area because it fits so very close to the muffler. The heat buildup there can be significant.
Wasn't a big concern to me. The brick OEM muffler was replaced within 1200 miles with a cat back system. My paint and plastic vents still look great. They were tested in the heat of TX during Rally 4!
Black GT
771
Get a Heffner cat back
DanQ
336
Lake Zurich, IL
For those keeping the stock exhaust, I wonder if some heat reflecting foil might not be a good thing to add?
https://www.pegasusautoracing.com/productselection.asp?Product=1838
There was a Heat shield cover made for the GTs about 2 years back. Midnite Blue has one.
Factory Muffler
Here's the best thing to do with the Factory Muffler! Tomy Hamon
Jan A. Byrd
39
Percy IL
What to sell your rear bumper? J Byrd.
bob700
Jul 13, 2007
10
That is what I had done. Some heat insulation material was applied across that area to protect the clamshell. Looks good and was not expensive. That area where the heat has the most effect on the clamshell is also the main support for the clamshell. I want to maintain that area's integrity.
I don't sell any parts I take off my GT. Sorry Tomy
It would be great if you posted some pics of your solution.:thumbsup
bob700
Jul 13, 2007
10
Pictures
Here is a pic. Some of the color you see is the resin which in itself acts as a heat barrier also.
Thank you for the follow up pic. Did you use the same reflective film from Pegasus?
bob700
Jul 13, 2007
10
I do not think so.
MR2Race
FGT The Velvet Hammer
Apr 6, 2006
304
Northville Mi.
Do any of the aftermarket mufflers have any insulation material?
Or is the hot gas contained only by a single layer of metal?
(With no insulation material surounding the can portion of the muffler)
tmctguer
129
dana point, CA
Bob700: Thanks for the picture.
I wonder if there is a benefit of putting reflective material over more surface area of the underside of the clamshell (longer lifespan of the clamshell, less long term damage to paint on clamshell,etc.)?
And the opposite -- would there be any detriment to covering more of the clamshell (reflecting too much heat back into the engine compartment, overheating the glass window, etc.)?
MR2Race
Apr 6, 2006
304
Northville Mi.
Anyone ever document what the under hood temps are?
Before and after a modification.
Some method to determine the amount of change?
Hot to the touch is too course an increment. .
tmctguer
129
dana point, CA
I was thinking about doing my own temperature testing. I am trying to figure out how to get a temp probe inside the engine bay that can measure ambient temps.
The things I wanted to test were: A. The "license plate spacer" idea (which sounds good given the huge hole sitting behind the license plate), B. The "muffler cover" developed by a fellow board member who works with thermal material, C. Reflective material placed on the underside of the clamshell.
The key is to replicate testing conditions on each attempt (e.g. Outside temp, length of drive, similar RPM, similar starts/stops, etc). No easy feat but if I can find time to test, and conduct similar test runs, I will post results.
MAD in NC did this with an infrared measurement device years ago. Look for his old posts.
MR2Race
Apr 6, 2006
304
Northville Mi.
I hope it was not a hand held infrared meter.
MR2Race
Apr 6, 2006
304
Northville Mi.
I have a few low buck thermocouple readouts I have been using.
For real time measurements.
That along with K-type wire, fused on the end.
Becomes a fine thermocouple for under hood air temp.
As well as a method to measure a surface temp.
Also have a solution for data logging the data if required.
