It is VERY rare that you will need to bleed the one on the firewall at all.
I agree with this especially if you use a Motive Power Bleeder which never lets the clutch reservoir get empty thus eliminating the possibility of getting air into the system. If you use the technique of pumping the clutch pedal and then repeatedly refilling the very small clutch reservoir then there is a possibility of getting air into the system if you accidently let it get too low on fluid whether you bleed the firewall valve first or not. I also only bleed the farthest point which also changes the fluid in the firewall point. Works great for me so far.
