Sway bar bushing kit & tires
DiegoR
Mar 1, 2012
17
Hi,
I'm looking to get set of new front sway bar bushings for a 2006 GT which has about 1.5k miles and the front front rattles, and turned out the bushings of the sway bar are shot.
So looking for these bushings, is not clear for me, if these are the correct P/N for them or are the links or brackets?
4G7Z-5C486-RH
4G7Z-5C486-LH
Or if anyone has them please let me know.
Regarding the tires, seems like the original size is NLA, but not sure if fits fine and all works smooth like intended with the bigger size?
245/40/18
325/30/19
I have some new bushings in stock..
Reactions: DiegoR
The Bridgestones fit fine. Do a search for the tire thread.
Reactions: DiegoR
Could you send me details through PM?
thanks
We have had new poly versions of the front sway bar bushes made - principally we did this because the stock rubber ones do harden over time and are pretty expensive for a simple D bush. The stiffness is similar to stock though this isn't so critical on a primarily radial bush anyway.
We sell these for £95 for a pair (less than we were paying for one stock bush) we can ship to the US with no problem.
Reactions: B.M.F. and roketman
If like to purchase a set from you for my inventory
No problem Ron - You have mail
thanks
I can but maybe you should order the aftermarket ones below as they will last longer
After 15 years and 35k miles, I replaced mine with the ones from GT101. Cheaper, will last longer, fixed that front rattle.
Reactions: GT101
