Hot weather coming. GT's run hot by nature, especially if you've stepped up the horse power. One easy way to stay ahead of cooling problems is to pick the rocks and bugs out of your forward heat exchanger. The GT has a stack of three units, the engine radiator is the third one back, so when air flow is reduced in the front, the engine core really suffers. Get some tool picks and pull up a chair. You'll need all three of the picks shown to be effective. Carefully push the pointy end under the debris at the narrow side of the fins and watch the stuff jump out. You'll be amazed what you find. You can also straighten any bent ones. Takes maybe 20 mins. I bet the total frontal area of all the stuff that I get out every month or so amounts to a hefty reduction in total airflow across the heat exchangers. This will means bonus points when it's 90 outside. Turn up the music and get picking.
