Need Help - Cat Pipe Removal
Status
Not open for further replies.
Fracman
284
I'm pulling the CAT pipes and am stuck on removing the passenger side (driver's side was a snap).
Is it possible to pull the pipe without removing the rear bumper, starter, or axle shaft?
I've got the o2 sensors pulled and axle shaft heat shield off but can't seem to find a path for the CAT pipe.
Any advise would be greatly appreciated.
Disconnect the half shaft flange and remove the bumper and rear screen. Then it will slide out the back side. Note that the stock halfshaft flange bolts are once use. The Accufab ones can be reused.
Fracman
284
I put my big boy panties on and removed the starter, I was able to finesse it out without too much trouble.
Thanks,
Chad
Status
