Door panel removal
BelgianGT
382
Belgium
Anyone know how to remove the door panel safely? I want to re-install the mirrors as they were taken off for inspection. I took the alu panel off - about six screws but it doesn't come off like that. I don't want to brake anything. Is there something like a repair manual do see where it could be stuck or other matter to consider?
You can call or email me and I will walk you through the process.
FYI once the aluminum trim is removed then remove all of the Torx and a small bug long Phillips screw at the outter corner of the leather trim panel. Then unplug the switches using a smaill 90 degree pick tool to press the detent in, and then with the use of blue tape and a panel tool it comes off with little effort.
All the best
