Backup camera integrated in auto dimming rear view mirror
jcthorne
792
Spent the weekend installing a Christmas gift from my family.
Installed this Auto-dimming Mirror with 3.3" Hi-Definition Rear camera Display
http://www.amazon.com/Gentex-GENK332-Auto-dimming-Hi-Definition-Display/dp/B004J0I19E
and this Ultra Slim Zinc Metal Black License Plate Camera
http://www.amazon.com/Boyo-VTL375-Ultra-License-Camera/dp/B002X8VF4C
Contacted American Security - the vendor for the display and they made me up a longer cable to reach the rear tail light area. Took quite a while to carfully route the cable from overhead near the mirror, down the a pillar, along the side rail and up to the seat belt area. Then through the existing bulkhead fitting and along existing wire loom to the tail light area. All cables in the engine bay using OEM style nylon braid protector sheath. Required no modification to any existing harnesses. All connections required are in the overhead except the backup light which I tapped with a single blade vampire spade receptical at the tail light harness.
End result is a very OEM looking installation and it WORKS great. No more blind backing into a parking space or out of one. Display comes on when the shifter is moved to reverse. The camera works very well in almost no light, IE the factory backup lights are more than adequet. The picture is very clear and stable. Also the Gentex mirror is the OEM supplier for many Ford and Lincoln products.
Oh, the auto dimming feature is very nice too when bubba and his pickup are behind you at a stop light....
Was a fun weekend in the garage with my GT. Just thought i would share.
What did you do about interior lighting?
Shadowman's dome light. Works better than OEM and I added an override switch into the headliner. It is right out of the Ford parts bin and IMO looks OEM! I added that when I installed Kip's 2Din a Pioneer unit with backup camera.
You could sell that as a kit if you assembled all of the components specific to the GT.
I ordered the parts from Shadowman, but it is really just some wires connectors and dome light. The key with the Shadowman kit is he walked me through the install. Without his help I would have never attempted to pull out the headline, because it isn't for the faint of heart.
jcthorne
792
Rather than using a plastic dome light and cut the headliner, I opted for an LED strip light across the back edge of the headliner / top of rear glass. I also used an OEM switch to turn on the light just in front of the clamshell release. The lights match those used in the engine bay and work very well.
I put the Ford-sold Gentex mirror with garage door opener, compass and temp in my Mustang. Later I got the garage door version for my Dodge truck. Gentex makes all (or almost all) of the self-dimming mirrors, and also makes the On-Star setup for GM. They have a great product!
Do you have a picture?
Was connection made under the console? Or somewhere else?
Just FYI - several people have installed such cameras and had them melt. Keep your eye on it.
Yes, you have to keep it as far away from the exhaust pipes as possible.
I remember seeing 3' flames shooting out of my exhaust pipes, in the bright noon sun, when my cousin lifted the throttle at the end of a mile run.
So far my Pioneer camera is still working great.
What location did you install your camera at, relative to the license plate frame?
How about protecting the wiring in the engine compartment, any suggestions for wrap or location?
It is mounted on the center top of the license plate.
Great old topic. After a little while I contacted Gentex to see if they would do a mirror with the backup camera and the GT-style lighting. Their answer was there was not enough market to justify the production.
