o2 sensor noise
Thanks, Jay.
I bought a Innovative Tech. LC-1 to datalog. It is the same as the one tested without the meter. I am pleased it got the highest ratings. I plan to use a SCT XCAL 2 to datalog with it. Installing it pre-cats in place of one of the stock O2 sensors. The LC-1 has two outputs from the same sensor. One is wideband the other simulates the stock narrow band sensor. Then I can log at anytime without taking the car apart.
I ran stranded CAT5e cable from the engine compartment to the drivers foot well. (it is want I had around) The exterior insulation is poor and not heat rated for an engine compartment, but I believe the 8 wires inside have high temperature Teflon insulation. Jay do you think there would be any noises issues in using twisted pair vs. shielded coax for the 02 sensor?
BlackICE,
I just bought the same unit a few weeks ago (naturally, before I ran across the article)! I can usually tell the quality of a product by the way it's packaged. I have spoken to their engineering team and they are on the ball... Today, I just ordered their new direct reading, wide sweep, A/F analog gauge. It's the cat's ass! Like you, I will also be data logging with the same SCT unit that you own. We must living parallel lives!
http://www.innovatemotorsports.com/products/g3_gauge.php
or
http://www.innovatemotorsports.com/products/g2_gauge.php
Isn't the cable from the LC-1 long enough as-is?
In regards to the additional wiring, I actually think that the CAT5 cable is an excellent idea. You could put a sheath over the cable to ensure better protection.
Your concerns about o2 sensor noise pickup is very valid. I looked at my LC-1 system and the o2 sensor has a 2 foot long cable which then plugs into the processing module.
This part of the cable will have a high impedance line (as you mentioned, the o2 signal), which is the most noise susceptible part of the system. The electrical signals at the output of the module are at a low impedance (
buffered), so there
shouldn't be a noise pickup problem. If you think that you're going to experience noise, you could put some braided metal shielding over the CAT5 cable and then ground one end to the car's chassis. The twisted-pairs that you mentioned will do a fairly good job of rejecting noise. I don't feel that there will be any problems with the unit as-is. The GT is fairy quiet on electrical impulse noise, probably due to the coil-on-plug ignition system. One other thought, proper grounding is very important to prevent voltage offset errors. Once everything is operational, check the voltages that you will be logging for good agreement with the SCT unit. It's a single-ended world out there...
I am going to weld a pair of SS bungs onto my new exhaust system. This will be
after the cats, however, I can null out any offset errors. Bill, "Shadowman" gave me some advice on this matter. I can just drive down the road with the engine operating "closed-loop", then electronically adjust my offset until the gauge reads 14.7 to 1. The readings will be slower due to the effect of the cats.
Keep us posted,
Jay
