Why right hand drive race cars?
Yesterday morning I was drinking coffee and reading an article about the yellow Ford GT Mark IV that finished fourth at LeMans in 1967. Henry Ford II was apparently aggravated when critics pointed out that his 1966 winner, a GT40 Mark II was not an American car but rather a British built car with an American engine. So he goes back to the drawing board and has an all American car built with an American engine and two American drivers. But he builds a car with right-hand drive that forces the drivers to hop over the top of the stick shifter thats mounted on the right door sill. What's the deal with this? :confused Do the rules at LeMans require right-hand drive automobiles or is there some advantage to this layout that I'm not seeing?
Don't know why - but probably something to do with simply a British car, no regulations particularly.
The Romans used to drive on the left - it is the correct side, leaving your sword arm free to defend yourself! :biggrin
I be;ieve the early British cars had the shift out side the right side fo the car, driver on the right side. When enclosed cars came on the scene, the Brits moved the shift to teh centre consule and kept the driver's seat on the right side to avoid having to change a generation of right sidede drivers! It is not simply a UK driving fad, most of the United Kingdom Coutries also drive on the right side. I actually enjoy traveling in the UK on the right side of the road.
:thumbsup
Most race tracks are mostly right hand coners this keeps the weight too the inside. It also lets the gear shift lever go back to the trans. without to many turns. Some early English sports racers had center shift this did not last long.
Chip,
I understand the point your making with the MKIV being a totally American built so why the right hand drive? So, I put a call into Phil Remington.
Phil recalls that MKIV was a CarCraft project headed by Roy Lunn. Roy was an Englishman but Phil doesn't think this was the reason for the right hand drive. But more due to the car being designed to run closed European road courses which were all run clock wise. Sitting on the right was thought to be better for both turning (visual) and weight distribution.
Chip,
That's interesting as most American tracks run counterclockwise. I didn't think it had anything to do w/the fact we are sitting in the lefthand seat, but thought it was just because we have a history of racing in that direction (ie, horseracing, track & field running, etc).
A little off "track", :wink but do you know if most European tracks run clockwise or is it just the English?
Like clockwork.....
Chip,
Straight from Phil Remington, uhh, yeah, that'll do. :banana Unbelievable, this forum never ceases to amaze me. Thanks Steve, I feel smarter.
