We did an engine oil and transaxle fluid change on my Buddy's 2006 GT. I then noticed that he has an additional external transmission cooler on the passenger side. Before I saw this we drained and refilled the transaxle with the correct fluid and it took almost exactly 4 quarts (which is also all I had ordered)
My questions:
1) How much fluid is "trapped" in the cooler/lines and how should I drain that? And how do I refill the cooler?
2) Although not ideal, I did not measure how much "old" fluid came out of the transaxle drain plug. When it stopped draining I refilled (again about 4 quarts) and the level was up to the fill plug...so I assumed that the plumbing does not allow the cooler to drain out the bottom drain plug (as it "seemed" to stop draining after a reasonable time/amount (again unmeasured)).
3) The "old" fluid looked pretty good so although my new fluid MIGHT be diluted with some of the old fluid, my biggest concern is that I might have drained some of the additional fluid from the lines/cooler and the system is not full. How can I check?
Thanks,
Tom
My questions:
Thanks,
Tom
