If the gauges are still in their boot up sequence AND you start the car, AND the battery voltage drops below some level because its getting old or poorly grounded, the gauges will fail the boot sequence and not work. Usually, just shutting the car down and back on again, letting the gauges finish the boot sequence before starting again will bring this condition back to working.....sometimes not. This sequence was what led many to believe the battery condition was the cause of the gauge failure. It still may be a contributing factor.
Anyway, its always better to let the gauge cluster finish booting before hitting the start button and if the dead cluster thing happens to you, clean the ground connection and or start looking for a new battery. Its a voltage drop issue and not necessarily tied to charge state as the battery age
This condition also existed in many of the early 05 Mustangs and a few other lines that had early data network gauges. Fortunatly they did not have the failure rate the GT gauges have after the fact.
As far as I know, the GT is the only Ford vehicle with the older gen PCM processor and networked gagues. The Mustangs and others used a later gen processor. No idea if they are related other than boot time.
