Standard Wheel Custom Center Cap
AZGT
1,354
Scottsdale, AZ.
A couple us have talked about making a center cap for the standard wheel. Well, for me the problem is solved.
I love the look of the standard wheels without the fake knockoff center. I used the lug nuts from the optional BBS wheels, and took off the casing to the valve stem so it is just rubber. With the center cap, to me, it looks like how it is supposed to. I actually like this better than any aftermarket wheel that I have seen so far.
The center cap is an OEM part - Ford part number 7L1Z-1130-CB. It is off a 22 inch truck wheel from the Ford aftermarket stuff. They are plastic press in with spring tension. There are four small tabs on the back that need to be removed so it sits flush against the wheel - very easy job. It fits PERFECT.
A couple of the pictures are with a different cap - before the Ford one just so you can get general view. The standard wheels have the same general lines / depth / form as the Optional BBS - it is just that the knockoff cap tends to make them look flat. They have a nice shape to them when they are "opened up".
BTW, the tires are the Bridgestones.
Pics?
Sorry - edited them for a second.
Very nice. I think I will see how they look on mine. Looks like they were made specifically for the wheel.
John
John
I think they will look nice on yours being that your wheels are fully polished! :thumbsup
On order. :thumbsup
John
With Derry's nuts .................. it would look great ! :thumbsup
Those look really smart - so that's just a standard Ford part (plus lug nuts)? I wonder if they're available in the UK?
My centers have discoloured....
Should be available. If not, let me know and I will help.
Yes, standard Ford part and the lugs that are with the optional GT (BBS) wheel.
I can assist with these items and ship worldwide if needed.
They look good:cheers
Thanks Torrie (and AZGT)...
Torrie, can you post a picture of the actual part as I'm a little unclear what is included. I can't find that part number in the UK - is it for a US model truck only I wonder?
Neil
I do not have a cap here on my desk to take a picture of I can get them though. 7L1Z-1130-CB = 1 center cap.
So you would need
4 X 7L1Z-1130-CB center caps
20 X 4R3Z1012-AA lug nuts
Didn't want Derry's nuts? You're very right - nice and clean.
I ordered mine and this the first mod I've seen under a $100!:thumbsup I'm sure there's others.
John
Neil
Here you go. Just a simple press in cap. The black arrow is where one of the little tabs was that needs to come off (makes it sit flush on the wheel). Perfect fit - perfect size - just a little bit of the wheel hub showing around it like it should. Looks made to order.
Great timely post...Thanks to Lee, (Somelee), I have a beautiful new set of 6 spokes designated for track use with Hoosier R6's. I have been contemplating either powder coating entire wheel black, and/or polishing the lip and painting the remainder black. Now thinking either completely polishing out entire wheel, or polishing lip area and painting the rest black with AZ's center cap look :thumbsup
So you would need
How much?
How much?
No charge to take off the valve stem cover :thumbsup Truly a cheap GT modification. Plus it saves weight.
WHITE IS THE FASTEST COLOR :lol
