Side mirror removal
I believe there was a thread on this but I could not find it. Is it possible to replace just the mirror insert in the side mirror housings? If so, how? Thanks in advance.
Yes you can replace the glass will the housing is on the gal
Press the mirror in as much as possible on the edge close to the gal and then grab the edges and it will pop out
The new mirror glass will then snap in place
Part numbers
RH 4G7Z17K707AA
LH 4G7Z17K707BA
The retail cost is $134 and change USD
Thanks (again) for your help. Did you come up with convex replacements?
As I recall STORMCAT was working on this or in fact had come up with a solution
Now that would be a real 'nice to have'...
StormCat has a post on this. He put a right side "Objects in mirror are closer than they look" mirror on the drivers side. Check his post.
Here's what I did....:biggrin
http://www.fordgtforum.com/forums/showthread.php?t=8061&highlight=objects+mirror
