Rotor Cleaning
eshrink
511
What are you using to clean your rotors?
- doc
4,211
A great road with a lot of "s" curves causing me to brake on the entry points........ :biggrin
What do you mean by cleaning the rotors? I'm very aprehensive about putting anything on the surface itself.... Regarding the spindle etc... just getting in there with a smaller stiff brush worked
FrankBarba
Permanent Vacation
544
Harrisburg, PA
break cleaner will work just fine. Just spray on watch all the dirt fall to ground....
eshrink
511
0000 steel wool works fine and is minimally abrasive. However, I assumed that others had found better means of removing oxidation.
Problem arises (down here) when I wash the car after a drive. Moisture on the rotors turns to surface oxidation and looks remarkably horrible.
"Break cleaner"? Brake cleaner?
- doc
Raising teenagers is like nailing jelly to a tree.
4,211
Doc, same problem in North Carolina... After the car is cleaned I just take it for a 1-2 mile spin..... Oxidation or surface rust disappears :cheers
abolfaz
827
Coral Gables
The "hats" on my car are rusting.
dbtgt
One lucky SOB to own a GT
Tulsa, Oklahoma
Stetson or Resistol? :lol
mbgt
9
the center / hub of my rotors are rusting and the dealer informed me today that it is normal. Anyone have a fix?
I believe aboflaz is having the same issue.
I think you want to use the term oxidizing. Rusting implies penetration. Ask Bony, he knows all about penetration.
abolfaz
827
Coral Gables
Same thing here, it looks like $HIT!
