The Power Rings are finally completed. After months of testing and hours of engineering with analysis, gtsaver.com is ready to take orders for the new support rings which prevent your air inlet bellows from collapsing at high RPM. These were recently tested on a car with a reduced size supercharger pulley capable of boost levels exceeding 15 PSI on a hot day, when the bellows material is most compliant!
This product will help maintain a more consistent A/F ratio at high RPM. As you update your car for increased horsepower, it will usually require more airflow. This solution keeps the air inlet aperture as "open" as possible by use of a special stainless steel spring alloy along with a very thick Teflon coating to reduce friction and wear with the bellows. The rings have different sizes to provide maximum efficiency and minimal obstruction in the airflow path:
http://www.fordgtforum.com/forums/showpost.php?p=18330&postcount=1
www.gtsaver.com
Shipping will begin on June 12th!
Thanks,
Jay
P.S. I really am working on the engine bay light!
www.gtsaver.com
Thanks,
Jay
