I don't have information on the design characteristics of the GT, but it seems that 75 psi is where the relief valve bypasses the oil. Long ago it was "established" in racing circles that you would expect 10 lbs per 1,000 RPM. But there were many fudge factors in this. You wouldn't have 10 lbs at idle and you wouldn't expect 90 lbs at 9,000 RPM.
So, with the GT, I would expect something above 20 lbs at idle and around 60 lbs at speed. When cold, you will see the relief valve limit of 75 lbs because the oil doesn't flow well until warmed. But you are relying on the relief valve to really control the oil and not let excess pressure through. You can actually blow off (unseat) an oil filter with too much pressure. The relief valve is usually used to relieve the cold pressure and not needed when the oil if fully warm.
If you are seeing 75 lbs pressure fully warm (190 degress or more) there are 3 things that may contribute to this. The pressure guage may be faulty, the oil weight is too heavy, or there is a restriction that would cause the pressure to be high all the time. It could be from some tight tolerances on a new engine. If the pressure goes down when the engine is really warm (220 plus), I wouldn't worry. But if it is high all the time, especially at 3500 RPM, I would be wondering what the cause was.
I'll check mine next outing so we can have another data point. But on my trip home, I don't remember going past 60 once warmed at speed.
