Motive brake bleeder cap size
Art138
663
Weston,FL
Anyone who has a a motive brake bleeder.....do you know the cap type (part #) which fits over the brake fluid reservoir? I have one made for Ford but diameter is too small.
Yes, but I have no idea what it is (I dont think there is a PN or anything on it). I called them, explained that what I had didnt fit, told them the car, and they sent me one that worked. I think I confirmed with them that it worked (this was a while ago).
I have the Deluxe model that came with several caps. I use the one that also fits a Wilwood 3/4 inch master cylinder if that helps when you call them. Unfortunately I don't see a number stamped on the caps.
This one?
Mine is probably 20 years old, so it looks like they have changed their package names since then. This is closer to what I purchased: 0260 The XLT Bleeder Kit. Did some research and you'll need cap #1100 (45mm) to fit the 05/06 FGT master cylinder. It's the 2nd from the bottom left in the picture.
Thanks!
I will give them a call...thx update: found one on eBay.
Glad you got one, as I looked today, no ID in any way past that is silver anodizing (I also have a blue, red and black ones, none are the same color)
