Installed TPMS system last week.
The Grey Ghost
704
Kansas City
I am as diligent as anyone when comes to keeping an eye on my tire pressures, especially with no spare.
I check them every time the car leaves the garage.
Having read previous threads on the subject, I know there are different views here on how helpful these systems can be.
While I know a difference can be felt when driving as a tire pressure drops, I believe these systems can provide an earlier warning and help avoid possible headaches associated with a flat. One of my bigger reasons was for longer outings.
There are a number of systems available, I chose to go with one produced by Schrader, who happens to manufacture a good portion of the OE sensors. I got the battery powered monitor, however they also have a cheaper set up that can be hard wired for power.
http://www.amazon.com/Schrader-SCH-...8-23&keywords=tire+pressure+monitoring+system
Parameters for each position can be programmed and a visual, as well as an audible, warning are activated with a 25% or more drop in pressure. You can also monitor on going readings in a one position at a time mode in which you scroll through each position, or set it in a rotation mode which scrolls through each position continually. (I found this distracting)
Only one outing so far, but it has worked great up to this point. It also monitors tire temps.
Found a perfect place for the monitor/receiver, and it is just mounted with velcro so I can access the Air Bag Switch if needed (doubt I ever will).
The monitor shuts off after lack of movement, and only takes the motion of opening the door to active the receiver.
Due to the shape of the rear wheel beside the valve stem hole, I did have to rotate the sensor 180 degrees to keep it hanging free, but that doesn't effect it's function.
I'm not advocating this as a replacement for regularly checking your pressures, but as an additional tool for on going monitoring.
That's pretty cool. I'm a believer in TPMS. Just a few weeks ago, I got a puncture in a Touareg tire. I didn't feel anything, but the TPMS warned me soon enough to get to a tire shop. Saved me a roadside tire change.
Did you install them when having new tires mounted?
Thanks for posting. And, I see you have one of the ultra-rare Stormcat bottle holders!
I put one in the GT too. $1.50 from Autozone.
Lol!
I'm just giving you a hard time Grey Ghost. That is a neat idea.
There's a new system just coming out based on simple valve stem caps with Bluetooth results to your smartphone, or a dash module. But the results simply on your phone seems pretty cool to me.....
Short version Gary, I have access to the equipment to do my own tires, so I just broke the bead down on one side, installed the sensors, reseated the bead and rebalanced the wheels.
I love Brian's bottle holders. Dr. Frank hooked me up with Brian after I saw his at my first rally in Austin. (Now Frank is going to want a commission) :)
See you and Amy next month.
Jeff
No problem, I can take it (and dish it out now and then) ;)
Thanks, Jeff
Man, you guys must not have been driving in the 70s
Cool idea! Since I'm about to change tires, this is a definite consideration. I poked around on Amazon, and there are several other brands, including those that will display to an in-car video system (maybe backup camera display?), and to a rear-view mirror. Hmmmm…
Here's another link: http://www.amazon.com/ORO-Technolog...bs_auto_5?ie=UTF8&refRID=15BXC4PHEMH2X6NK7Z4P
Save your money to pay your tangible personal property tax. :lol
We also had bias ply tires (with a spare) and drum brakes all they way around. :)
No reason not to take advantage of modern technology.
I know I like the idea of tire pressure monitoring and I was definitely driving in the 70's
I'm curious to know how pressure which is on other side of valve stem would be picked up/read
I assume whenever it is screwed on it opens the Schrader valve, exposing the internal pressure to a sensor in the device, and when removed the valve closes until you open it again in the process of adding air.....
Interesting....
Any issues with the tires spinning really fast (like 200MPH)?
Interesting....
Only had it to 135 since installed and no problems up to that point.
Hope to be able to test them at quicker speeds in 3 weeks. :)
Love the idea of TPMS but not to sure about schrader valve being held in open position by a stem cap, maybe ok but worries me a bit
I would think they would be similar to the caps that show the pressure in the top of the cap, turn green when at the preset pressure, or the valve stem extenders used with hubcaps. I have seen these styles leak after time.
I think Paul has the right idea -
