Not that this has happened to me yet but since the battery mounts inside the trunk and the trunk access is electronic how do you open the trunk to change a dead battery???? -- Ole Blu
confused:confused
Everyone should try their manual trunk latch to make sure it works. Mine doesn't. Took the business end apart to see want was wrong. There is a bulb like thing on the end of the cable that gets pushed into the latch trigger thus opening the trunk when the handle is pulled up. The cable is intact and if I manually pull it from the housing the lever by the fender/door will pull the cable back into the housing when the lever is placed in the closed position. So the problem is on the lever end of the cable. I plan to remove the fender liner next and see what the problem is on that end. If anyone else has already been there I would appreciate any comments. I would guess if the battery went dead and you plugged a battery charger or other jumper source to the vehicle the remote would open the trunk. I have not tried it though.
AJK
...The jaws of life...
(No! 'Actually what Shelby said!)
