Fumoto Valves for engine block coolant drains
AJK
337
Has anyone installed the Fumoto valves for draining coolant from the engine block? If so what is the correct size to order. I have found it to be a bad experience. If no one has installed the valves does anyone have a suggestion to avoid the mess and taking a coolant shower?
AJK
LMAO. I remember the first, second, ..... and nth time doing this. Each time holding a pan to no avail. Seems that more always gets on you than gets in the pan. Nice idea that you have about the possibility to use Fumoto valves but I haven't seen one with a pipe thread.
I thought someone already did it here (Clinton?)?
I use them for oil drains, not coolant.
They work fine with oil and no pressure. Not sure about anti-freeze and 20 psi? I looked at one on the shelf and can't see what seals the ball.
It's a spring loaded steel ball on a nylon-like seat.
