I'm thinking you might want to change your part description request. The hub assy. is the rotating bearing assy. which Ford has over 300 in stock. the upright knuckle is probably what you may be asking for. the RH and LH are unique. the RH is on a serious back order. hope that helps and good luck with your quest. Ford's part description does call it a hub so you are correct.
[/QUOTE
I'm looking for the wheel bearing hub assembly ..ill check again with the dealer.. thanks
