Most likely your clamshell or trunk are not fully closed. Open and close both (and while you're at it, the passenger door), but don't treat it like it's a newborn baby. I see people close hoods by lowering them until they touch and then "pressing" it to latch. Try doing it with some authority - lower to about 8-10 inches and then let it fall. I had problems with my clamshell until I started doing that.
I'll slam harder!
When we had the GT guys clamshell latch inter-connect (highly recommended btw) - I got the same thing. We of course thought it was related. Couldn't figure it out. Put a OBD scanner and found out it was the front hood (there is a windshield wiper behavior confirmation of this). Was just a coincidence.. Go figure
No need to slam it. From a height of 6-8" just let them drop. No force, just let gravity work.
Good luck!
There is an OBD port under the left dashboard. There is an electronic apparatus you can buy that plugs into it and will read error and service codes if something is not working correctly.
If none of the above work take a look at the switch on the clam latches. I think one of those was loose once for me, if I remember right I just pushed it back in place.
Good luck!
It is the clam shell. I have been closing it as you described, with a gentle touch. I feel a bit skittish about droping it but I'll give it a go. Thanks.
