Does trailer winch need fairlead?
REDEEMED
142
Since the FGT winching hook is offset, is a fairlead necessary on a center-mounted winch?
FBA
1,672
31.022340° N / 44.846191° W
I have pulled the GT with a winch, into my trailer with the winch mounted dead center on the floor. I had no issues with it, although, I'm guessing if you want to be 100% safe, you'd want to pull straight rather than at a slight angle.
I just winch it in, with out issues so far.
I have a center mounted winch too.
I use my thick leather gloves and try to 'lead' the cable to the right of the winch spool as I winch in the Vehicle . (right side when looking at the winch) so as to not let the cable 'pile up' on the left side of the spool and become 'bunched".
ajb (andy)
jcthorne
792
While on the subject of trailer winches,
I plan on installing a winch on my new trailer that is being built. Is a 3000lb winch sufficient for moving the GT onto the trailer with ease? I was thinking of installing this one:
http://www.amazon.com/gp/product/B001Q399RA/ref=ox_sc_act_title_1?ie=UTF8&m=ATVPDKIKX0DER
It looked like a pretty complete kit for the price and a good brand. Trailer comes with mount and battery tray, cables.
FBA
1,672
3000 LBS is a bit low, considering that the car weighs more. I had to choose between a 3K and an 8k. I went with the 8k unit.
jcthorne
792
I was not planning to lift the car off the ground, or use it for off road recovery, just roll a car onto the trailer with a 5% incline. And while I am not trying to be a cheapskate, there is a significant difference in price that would be wasted if I don't need the capacity.
Then again, if someone has already 'been there and done that' and can lead me away from troubles, I want to learn from others experience.
Mine is a 4k, pulls in no problem. In fact last week, was loading the car, it was dark and raining so was hurrying as the window was open to ajust steering angle, i did not get the ebrake off, still pulled it in.
Seank
Texas Mile Record Holder
Jun 2, 2011
17
Katy
We have a 4500lbs Warm Utility Winch in ours, comes with about 60 feet of cable. I see they have a 4700lbs now and don't carry the 4500lbs any more. I would just compare the gear ratio and HP. The rating is usually on the cable as if you use a pulley system you can double the capacity, but your gear ratio and HP might not be able to pull it. Below is a link to Warns site, you can find it elsewhere for cheaper.
http://www.warn.com/utility/dcwinches/DC4700.shtml
Nafod
Cooltech has a nice tow hook extension, that should keep the cable/strap away from the car.. I havent tried one, but would/will when I decide on a trailer.
jcthorne
792
Now that was a good idea! I ordered one!
Speaking of orders, I finally placed a factory order for a Kwikload rollback trailer. Aluminum deck, fenders and wheels, spare tire and mount, 3000# winch, 100Ahr battery with charger, Faring, full length side rails/tie downs, 4 wheel electric brakes with Tekonsha trailer mounted RF brake control, built in flush lid tool boxes, LED lights. Midnight Blue epoxy paint. Finished weight approx 1350lbs with a GVWR of 7000. Should be ready for pickup about May 15th. They suggested a few changes when I told them it was for a GT, having built several for this application in the past.
MDT
Love to see some pictures of that trailer when it comes in.
Beach-GT
887
Seminole Florida
Me to and the price.
BIGFOOT
751
Northeast
I have a Superwinch S5000. Bought at Amazon. Easy install and was a great deal. 5000lb capacity.
jcthorne
792
I'll post pics when I get it. As for price, with the options it was just under 7k. You can see the trailers and how the rollback works at www.kwikload.com
