Your grommet is damaged, split in half with the ball-side half missing ... which is the half the ball should pull against. See my pic below of my (surprisingly) undamaged grommet, and below that is @TORQJNKY 's undamaged one removed from the car. I think it's supposed to be pushed up into the upside down U so the metal ball doesn't pull directly on metal, and so the cable only ever touches the grommet rather than metal, and the grommet fits firmly into the U to retain the cable and ball in the U.Well, you guys have made me sufficiently nervous that I cannot leave my clamp release alone. On my GT the rubber washer on both clamps slides freely along the cable. Nothing prevents the cable from falling down, out of the slot in the release mechanism. Is that rubber washer supposed to be attached to the back face of the release fork (cemented? pressed in place?). If it was, it isn't any more on my car (first image). I propose to cement it to the back face of the fork, which will prevent the cable from dropping out of the slot (second image). What are your thoughts?
@TORQJNKY 's undamaged one removed from the car:
