Adjusting Clam Shell so it doesn't rub at rear?
canadiancobra
67
Edmonton,Alberta
I've done some searches on this topic and havn't had much luck. When I open the clamshell the paint is rubbing the paint on the shell and the rear spoiler area on both outer sides. Just barely but enough that it is wearing off the clearcoat!! Has anybody had to adjust the clamshell forward or the rear piece back? Any suggestions or tech articles available? Thanks
I think i found my answer. Just had to look harder! Thanks John
http://www.fordgtforum.com/forums/showthread.php?19099-Clamshell-alignment
send me a pm with your email address and i will send some pdf's that tell and show the procedure
Viva GT
I sent you a Visitor Message on your profile page as I can't seem to PM people as the forum tells me I don't have access?? Anyway my email is [email protected]
Appreciate the help. Thanks John
I used the thread you posted above to adjust the rear fascia. It is a very straightforward procedure.
Viva GT
Send DBK an email and he will change your status. You should be able to PM from then on.
You need to be a subscribed member to do PM's. You might consider joining as a paid member.
