AC fan control not working
Rstomp
29
Naples, FL
My 2020 GT, L071 is having a problem with the AC fan control. The fan works and air blows if the rotary control is at 1/2 or less. If it is turned up above 1/2, the fan shuts off. Anyone have a similar experience and have a solution?
Art138
609
Weston,FL
This has been posted before. Make sure the nob has not slipped around the fan control shaft. Try taking the nob off and ensuring the shaft is at the off position and reposition. I am always very gentle when I turn the control. There is a thread somewhere on this subject.
Reactions: 2112
Art138
609
Weston,FL
Sorry just noted it was a 2020…disregard.
I am assuming by 1/2 or less that the position is in a clockwise direction. Left of center works, right of center doesn't.
Is it absolute position or does it vary? (ie, is it an analog position or perhaps a digital position.)
The earlier mention of the knob and set screw would make sense if it were in the CCW direction but not for a CW rotation...
So, I wonder if the fan speed is on two different circuits where at lower speed a lower current winding is used and at that position in the rotation it switches to a different winding (and thus, perhaps different fuses/relays)... It'd be a place to start.
Warranty? Maybe you should get EverythingBreaks.com :)
Italian Joe
Rstomp
29
Naples, FL
thanks for the comment. Fan operates and increased speed as the knob is rotated clockwise. The fan shuts off as soon as the knob gets to the half speed point, then it shuts off. I'll have to check for a high speed fuse. If this doesn't work, looks like I'll head into Galloway Ford and see if they can diagnose. Out of warranty
FlagstaffGT
Mine turned out to be a simple calibration procedure. Trying to remember, and posted here earlier. put all rotary switches in mid position. Then turn on ignition while depressing recirculation button. Within thirty seconds rotate all rotary switches full range twice. Found it. Click link below.
Reactions: twobjshelbys
Rstomp
29
Naples, FL
Thanks for the info. The re-calibration worked. Appreciate the help!
Wow. Cool
