Where to get the wired axle bolts?
bonedoc
27
Wichita, KS
Does anyone know where I can get the axle bolts with the wire holes?
Yes, go to www.thegtguy.com and Dennis or Rich will supply you with the bolts and washers. They are back-ordered according to Larry. Question what is your vin and year, not that it matters since it seems all cars need to be checked and once the washers are decompressed need to be replaced.
Any one have a torque spec handy for these two tiny little bolts?????????
TIA
:thumbsup
specs
TIA
:thumbsup
'Read in a Forum post somewhere 30 ft lbs. (But, dbl check that just in case... I for one was surprised it was that "low".)
'Recomendation is to "blue" Loctite 'em too...and be sure that the bolts & 'holes are SPANKY CLEAN and dry B4 applying it.
(If anybody remembers/knows for sure that 30 ft lbs is WRONG - pls post ASAP!!! )
E.P.
Thanks EP
Thanks EP
You betcha ...
(I'll bill yuh later...)
E.P.
