Steering wheel trim
GaryCGT
Jan 17, 2020
8
Hello.
Does anyone have the trim above the steering wheel for sale?
Mine has had terrible alarms/immobilisers installed with LEDs cut into the trim, so want to replace.
Many thanks
They are described in the Service Manual as upper and lower steering column shrouds. No part numbers are given. Try Tasca Ford parts search or maybe at X2 Builders.
69b302
130
Upstate NY
I believe the part number is YS4Z-3530-BBA Shroud Assembly - Steering Column. See mixed info on availability, and may cross over to other more common cars. Have you tried Ford yet?
GaryCGT
Jan 17, 2020
8
Thanks guys. I am in the UK and my Ford dealer are utterly useless.
My other option is to fill the whole and have it trimmed in leather, but would rather just replace
Did you try GT101? He's the EU guru.
NorthwoodGT
1,217
Michigan
easy peazy. not even a unique GT part.
YS4Z-3530-BAA UPPER HALF 5 in the warehouse
YS4Z-3530-CCA LOWER HALF 2 in the warehouse
GaryCGT
Jan 17, 2020
8
Ill go back to my Ford dealer with this info see what they have to say. Thanks!
Thanks Scott. I was surprised the part numbers were not listed in the Service Manual, but I have an 05 version and maybe they are in the 06.
GT101
*UK Support*
402
Colchester, Essex, UK
We can certainly get those - they are left hand drive Ford Focus parts so one of the cheaper items to obtain.
If you need help just give us a shout.
Reactions: GT Tech
NorthwoodGT
1,217
Michigan
there is also a rubber grommet that goes around the ignition key opening.
I believe it's a Mustang part F5RZ 3A566-A
also I always use a small drop of super glue on the tabs of the upper and lower column shroud
where they join together. they always seem to pop apart if you don't.
fordgt6
123
East Lake Weir, FL
I have one and can ship to the UK if needed
Reactions: GaryCGT
