Power steering pump leak
I have a leak at the hose fitting on the pressure side (see picture). I tightened the flare nut but it’s still leaking. Is there an internal o-ring on this fitting?
Paul, Yes it swivels and has a o'ring internal. 1,200 PSI on the high pressure hose. I've seen the line blow out of the swivel. A new line will be needed to repair properly. Ford sells the fitting but I have not had much luck releasing the internal swivel.
Thanks so much for the information David. I really appreciate it.
Reactions: 68Rcodeman
