Oil Pressure Gauge
mmlcobra
1,228
Lost my first gauge today in my '05.
Oil pressure gauge at 0.
Car is fine.
Prefer not to run without an oil pressure gauge!
Sender first????
Best,
Mark
Yes sender first. Pretty easy to do yourself.
If you do need to replace the gauge, do all of them together.
Get them directly from Autometer
Car is fine.
Sender first????
Best,
Mark
Got up to Waveny around 7:15, didn't see you!!!
Don't just throw parts at the problem, test the sender first. It's easy. Procedure is in the manual, but IIRC (getting more iffy as I get more ancient), if you ground the wire to the sender, it should make the gauge read full scale. Or something like that. :unsure:
Thanks guys.
Will check the sender first.
RPM, I was there at 0630.
Was packed.
Best,
Mark
