Joe's TTGT current numbers?
04mach1
214
Small town ohio
I reread the entire article in MMandFF. It said bigger turbos were coming and they even thought about putting GT42's on it. So I saw the 1450rwhp numbers is that the maximum or did the GT42's go in and it put down more rwhp?
Thanks,
Nate
1,450 = land missle .......and you need more :eek
I would think he has already broken the Mark Donahue rule:
"You know you have enough horsepower when you can make two black lines from the apex of one turn to the apex of the next".
:thumbsup
There are many types of racing and performance measurements. The Hennessey Viper went 225 mph in the Maxton or Texas mile. Sure would be fun to see a GT top that.
You would know better then I would but I belive joes car could possably do it. His car does put down quite a bit more power and it is known to hook with all that power too. I know that comp coupe is quite a bit lighter but It would be very intersting to see what it could do.
i would like to see this car go faster than the veyrons top speed of 253 mph. it has the gearing to do it. :usa
One of the issues with running in the mile events is the tires and traction. A high speed rated tires is not going the give the traction that a drag slick would produce. Ripper02's Viper has run in the 8's on a drag tires. That kind of 1/4 time couldn't be replicated in a mile event.
