Ford GT Engine/trans run stand project
B.M.F.
1,882
Minnesota
A few pics of a project I’m working on for a customer.
This will be a running GT engine using a ford racing control pack for a coyote, gt500 wiring harness and drive by wire throttle body. I did this because it’s very easy to wire and you don’t have to worry about a throttle cable and such. Yes it will only use one set of injectors but it’s ok cause it will only run and rev up and make neat sounds.
ultra low mile engine, will have a polished Whipple 3.4 on top, I had the ford racing exhaust polished and it turned out amazing. I’m going to make a simple cooling stack for it and it will not hold a lot of coolant but enough to run it some and impress your friends. Lastly it will have a glass table on top of it.
I built one for my self too so I can test transmissions and run engines out of the car.
Wow, Dan- very cool! And that Ford Racing exhaust is like exquisite jewelry.
Reactions: B.M.F.
Ultra cool!
Best.
Mark
Reactions: B.M.F.
That is sooooo cool. I have one of those little plastic models of a Porsche flat 6 see through motors with working cams, valves, little spark plug lights, etc. that also makes engine noises. My wife teases me since every now and then she can hear when I turn it on in the game room.
Can you imagine if I had one of these in my game room?
