external battery charger help!!!!!
dhbydesign
Aug 21, 2007
19
I need some help first off the solar charger i have been using failed, battery is dead and come to find out the key will neither unlock the door or the trunk, lucky for me i left the wind cracked enough for it to be opened, but i still am faced with trying to now charge the battery. i assume there is a cigarette lighter charger that i can buy to do the trick till i can get it open and take it to the dealer nand let them figure this out, also who makes a battery charger extension that we could add to the car for trickle charging thanks for any insight in advance:ack
Kendall at Cooltech can fix you up. He has the perfect product for this.
http://www.cooltechllc.com/servlet/Detail?no=4
:agree: Kendall is da man :thumbsup
You can go to any Harley shop and buy a float charger for $40, or Pep Boys, etc. Battery Tender makes great charger. Kendall has a great set-up kit that covers all the bases and convenience. Don't use a quick charger or you'll boil the battery and get acid on the carriage.
Cooltechllc.com ala Kendall. If you have a late 05 or 06 the hidden plug in grill is great. Even if you leave the car plugged in and drive off it only dis-connects! :bored
also,,,, don't trust a solar charger north of St. Louis after labor day! :rofl
Ford sells the GT Charger that came with car in pouch for $75. Vendors here have it.
...Nobody even bothers to SELL those here in the Pacific Northwest.
('Be like sellin' parachutes to submariners...:mad)
Take the battery out and go to Advanced Auto, Autozone, Pep Boys, whatever local auto parts store and have them check the battery to see if it will even hold a charge. If it won't, buy a new one. If it will, order the battery tender kit through Kendall at Cooltech, hook it up, and it may take a couple days for the battery to fully recharge. You can also have the auto parts store charge it for you while your already there.
