Excessive Wind Noise
Shark01
639
At higher speeds (like 60 mph) we start getting a lot of wind noise. It sounds like it is coming in around the windshield (or somewhere in front of us),but the last time we drove, the passenger and I felt around the circumference of the glass but didn’t feel anything. I did have to put some RTV on one corner last year to plug a leak (don’t know if that has anything to do with this).
Has anyone had any wind noise issues?
Believe it or not, you might want to look at the rubberized door release button. Turn car on, switch on AC full blast, get out of car, close doors with Windows shut and then feel around the door open buttons. You are in a warm climate so you should be able to feel if it is leaking. Driving around with Windows open may cause the trim to loosen up and maybe delaminate.
yes but have also not been able to figure it out
does sound like it is coming from around the windshield
Chances are, someone leaned on the door's roof and bent it enough to make a small misaligment.
