cimaxgt GT Owner Jun 7, 2007 76 Oct 24, 2007 #1 how much torque on flyweel bolts, torque on clutch plate, and torque on transaxle bolts. Please advise I am ready to install my re-manufactured clutch and original tranny. Last edited: Oct 24, 2007
G GT Charlie Member Jun 23, 2007 16 San Francisco Bay Area Oct 24, 2007 #2 Specs Torque Specifications Description Nm lb-ft lb-in Transmission-to-engine bolts 47 35 — Output shaft speed (OSS) sensor bolt 11 8 — Output flange bolts 30 22 — Drain plug 27 20 — Reverse lamp switch 27 20 — Fill plug 27 20 — Starter motor bolts 48 35 — Shift cable-to-transmission bracket bolts 26 19 — Transmission mount nut 200 148 — Muffler bracket bolts 25 18 — Starter terminal nut 9 — 80 Lower pan bolts 7 — 62 Upper crossmember bolts 27 20 — Transmission mount bolts 25 18 — Gearshift lever bracket bolts 25 18 — Gearshift control bolts 19 14 — Halfshaft hub nut 400 295 — Halfshaft boltsa — — — Torque Specifications Description Nm lb-ft Pressure plate-to-flywheel bolts 26 19 Remove the bolts and the flywheel. To install, tighten to 80 Nm (59 lb-ft) in the sequence shown. Last edited: Jan 8, 2008
