Does any one know a safe rear jack spot
Kurt Tompkins
New member
Sep 30, 2006
3
I am planing on running drag radials tonight. I can not see any place to jack up the rear of the car with the belly pan on. Thank's for your help. Kurt
Quick jack point
I use a piece of hard wood glued inside the floor jack pad W/ silicone.
So the points of the steel pad do not dent the belly pan.
Then from the side of the car. straight down below the Door lock.
Looking at the belly pan you will see a row of pan head fasteners. running from the sill toward the center of the car.
If you place your protected jack on this row of fasteners.
You can lift the entire side of the car. Allowing you to change both front and rear tires. The fasteners I am calling out are screwed into a large aluminum extrusion frame member. That Just happens to be in the right spot for field service.
Do not forget jack stands, placed under the cutouts in the belly pan.
There 2 in the front and 2 more in the rear. To find them, look for exposed sections of cast frame nodes with a hole in them. Used for frame fixturing at the build. :thumbsup
Thank's very much for the help. This is my first time on the forum. It seems like a great source.
Read this first!
Kurt,
Since I have talked to and read about too many bad lifting experiences, please read the link below before you dig too far into this project, as it shows some safe lifting points:
http://www.fordgtforum.com/forums/showthread.php?t=769
Good luck,
Jay
www.gtsaver.com
