Coolant temp question
Anderson
29
San Diego & FL
Is it normal for the degas bottle for the supercharger coolant to be much hotter to the touch than the degas bottle for the engine coolant? Perhaps there’s an air pocket trapped in there? I can see coolant flowing when warmed up so it’s not the pump.
No
Follow the lines again. IC is outside the frame, engine is inside the frame.
No
Thanks. It’s definitely the IC degas outside of the rail frame.
The oil level in the supercharger is good and appears to be golden color, not dark or burnt smelling. Next step is I'm going to drain the old coolant and change it out under vacuum. I will probably be adding water wetter as well.
