Never throws a check engine light and no codes other than P1000.
So the fact that it has not thrown another code is unusual however not without history
The P1000 code is as follows;
Ford OBD-II Trouble Code P1000 = OBD-II Monitor Testing Incomplete
Typically this will mean that the gal is not in OBD II readty mode meaning that one or more of the systems has not checked in and happy.
I just looked in my programming software and it is a code that can be disabled however there is no clear description
Here is what I would say;
1. ground issue = no
2. general electrical issue = no
3. condition of fuel issue = no
4. spark plugs = no
5. coils = no
6. general air flow into and around the intake = no
Now having said this I would say that the number of possibilities are minimal;
1. fuel filler tube assembly = maybe and most likely
2. IAC valve = possible but would remain low on my list
3. throttle switch = possiblke but would remain low on my list
4. pcv valve = possible but would remain low on my list
I am simply attempting to walk the distance with you
Regards
