Driver door hanging low?
SRG.GT
work hard--play hard
Mar 12, 2009
25
Hudson, Wi.
Hello all. New member here. Has anyone had a low hanging door on their gal? I have alot of slop on the driver door (lifts up and down, when opened, about 1/2" or more). Wondering if the housing is wore or the pins need replacing. Any thoughts?
I have definitely never experienced this in a GT. I would pm thegtguy. Any details on the car and when it was built?
How about lose (missing?) hinge bolts? It's waaaaaaaaaaaaay too soon for the pins to have worn out ...even if the car's serial # is "1" and there's 100,000 miles on the car!
Welcome to the board... enjoy this place... seems like something is very wrong with your door.... never heard of that issue before.
jaxgt
2,795
Perhaps a prior accident or body work? Do you know the full history of the car?
SRG.GT
Mar 12, 2009
25
Hudson, Wi.
The hinge seems to be tight and fastened securely, there is just some movement within the housing where the hinge comes together. I purchased this car last summer from a friend. He is a pretty big guy. I assumed that the door was used as a lift assist in getting out of the car:frown.
how many miles on the car, any body work? I have this on my car I tried replacing the pins and that did not solve the problem, so after I replaced the pins then I just gently lifted on the door to move is back up. this works well for a while then the door settles and requires a gentle lift from time to time, when the gt guys come down next time Im going to have them look at it.
As a new owner, you may reposition the door when you hit it a few times with your head. :rofl
Get the GT guys to look at it.:thumbsup
shelbyelite
PERMANENTLY BANNED
May 10, 2007
Check to see if the TWO TEETH that the top of the door sandwich with. There is some adjustment there and I have seen those make the door move up and down before....
4,211
To Shelby's point....
is the slop experienced when the door closes to the teeth at top? or...
the damn thing just moves up and down 1/2 inch when it's in wide open mode?
thegtguy
*Supporting Vendor* GT Owner
Apr 20, 2006
546
MI
Bushings
My thoughts are if there is "slop" in the hinge assembly around the pins it could be that the bushings are missing because someone had the door off and didn't reassemble it correctly. I know I always think the worst. Or if there is no "slop" and the door has dropped a little it is probably because the door was used as a handle to assist getting in and out of the car and it tweaked the door where the hinge bolts to it. If that is the case then the door just needs to be repositioned a little to fit properly again. Then the stricker and the "batwing", as we call it, will need to be readjusted again. I like to think of adjusting doors on a GT an art form.
For example if you are replacing a door assembly on any GT you can not set gaps and margins until the door is completly built. If you do this before all of the glass, regualtor, etc is installed it will be a little high and you will have to readjust everything once the correct weight is on the door. In development they actually had to put extra strength in the chassis a-pillar to compensate for the total weight of the door because some of the prototypes doors were sagging.
jaxgt
2,795
Does this guy know his stuff or what
:rofl:rofl:rofl Ya think?!
Not 4N
Tungsten GT Owner
887
Calgary AB
The term "Been there - built that" comes to mind. :thumbsup
4,211
Go Rich GO!
tpraceman
THEE GT OWNER
2,835
Washington Michigan
Rich you could just place a floor jack under the door and bend it back:eek
All this tech talk is just to show off your talents:lol
SRG.GT
Mar 12, 2009
25
Hudson, Wi.
12000 miles. No body work. Sounds like the same problem as your door. I just lift a little as I close the door to keep from rubbing on the top right corner of door frame (receiving) as I close it.
SRG.GT
Mar 12, 2009
25
Hudson, Wi.
As long as I lift the door slightly when I close it, The teeth mesh with the door correctly.
SRG.GT
Mar 12, 2009
25
Hudson, Wi.
When the door is open in any position, you can lift on the end of the door and feel that the door has dropped just enough to cause this problem.
SRG.GT
Mar 12, 2009
25
Hudson, Wi.
When adjusting the door, is the only adjustment up/down, left/right or can the hinge actually be tipped to correct my problem
I will look closer at the hinge assembly when I tinker w/her this weekend.(gunna change the oil):thumbsup
Thank you for all the feed back.
