During the yearly car preparations, I typically replace all 4 rotors, pads, fluid, along with an oil change, and from time to time flush the trans axle fluids. I know the GT Guys are scheduled to be with 100 miles next month, and I had purchased the accessory and supercharger belts from Torrie; buying the oil pump belt thru my local dealer. I think I was too late to schedule anything with Rich and Denis, and after looking at how little room there seemed to be and how complex it looked, I was hesitant to change the belts myself.
Then, I made a call last night to our friend Shadowman, and we talked for a while and he convinced me to give it a try; with the old “call me if you run into any problem and I’ll talk you through it”. First thing in the morning, I backed it onto the Race Ramps, and followed the book, for the most part. Though Shadowman suggested it might not be necessary to remove the engine access panel behind the sub woofer, that was my first step. Having not had it off in the past, I wanted to take a look.
Working on my back underneath the car, and not being a small fry, there was a bit of difficulty removing and later replacing the oil pump belt, and for me, through the passenger compartment was the only possible way to reach the top cover bolts. The large belts were surprisingly easy both to remove and replace. I remembered Shadowmans tips on the belts, and in the end, used a ratcheting tie down with one end wrapped around a nearby section of frame and the other to the breaker bar pulling on the tensioners as a final check making certain the belts were in their grooves.
In a few hours, taking several breaks along the way, the job was complete. I kept Shadowman informed of the progress with e-mails along the way, and as I was underneath the beast snugging up the last of the oil pump belt, he gave me a call checking on the progress. As he has always in the past, Shadowman has proved invaluable to me.
And finally, as always, if I can do it, anyone can.
Here are a couple of shots I took, of something.
http://1fordgt.com/2011/Ford_gt/February/3BeltChange/Garage001.JPG
http://1fordgt.com/2011/Ford_gt/February/3BeltChange/Garage002.JPG
http://1fordgt.com/2011/Ford_gt/February/3BeltChange/Garage003.JPG
http://1fordgt.com/2011/Ford_gt/February/3BeltChange/Garage004.JPG
http://1fordgt.com/2011/Ford_gt/February/3BeltChange/Garage005.JPG
http://1fordgt.com/2011/Ford_gt/February/3BeltChange/Garage006.JPG
http://1fordgt.com/2011/Ford_gt/February/3BeltChange/Garage007.JPG
http://1fordgt.com/2011/Ford_gt/February/3BeltChange/Garage008.JPG
http://1fordgt.com/2011/Ford_gt/February/3BeltChange/Garage009.JPG
Pete S.
Pete S.
