Now that the peak of summer is here, I notice that the water temps on my '05 with Whipple and X-pipe seem to be running higher than I remember last year, about 200 degrees when cruising at 80 mph in 6th gear. So I took my stock '06 out today for comparison and sure enough it only got up to 180 degrees under similar conditions.
The only issue I've had with the '05 is a slight coolant leak that has caused me to add a couple of quarts of coolant to the system recently. I didn't mix it 50/50, just put straight coolant in the tank. The level is correct but my question is....will a 60/40 mix of coolant/water cause the car to run hotter or do I have another problem?
I had the a/c running on both cars and the outside temps were about the same. Would the Whipple or the tune cause this?
What are some of you other guys with Whipples seeing for water temps right now?
Suggestions?
Suggestions?
